주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Why is my trackpad not working properly?
The trackpad on my Macbook suddenly stopped responding properly, when I move my finger the cursor stops intermittently. I found two workarounds that might give some clues:
1) if I apply even just light pressure under the trackpad the cursor moves as it should,
2) it also works if I unplug the power source, ie. in battery mode! (not ideal, since my battery is seriously bad)
Any ideas what might cause this problem?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Thanks guys! As it happens, the trackpad started working again before I could try any of your suggestions. If I had any less experience with computers I would say this is very strange…
Now I have the problem of USB-Midi not working with the power source attached, but that’s off topic…
@mholmqv - I would still look at your battery as this sounds like a classic case of a swollen battery.
댓글 달기
답변 2개
가장 유용한 답변
It sounds like you have a double whammy here. If your Battery is going it could be pressing on the trackpad from below, often times the battery swells up. I would test it using CoconutBattery Post a snapshot of the main window here so we can see how it looks 기존 질문에 이미지 추가하기. If needed replace it and you still may need to replace the trackpad and its cable if they got damaged. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement which is the same process for your system. And here’s the battery info MacBook Pro 15" Unibody Mid 2010 배터리 교체
MacBook Pro 15" Unibody Mid 2010 배터리 이미지
안내서
난이도:
쉬움
10 - 45 minutes
MacBook Pro 15" Unibody Early 2011 Trackpad 이미지
안내서
난이도:
운영
45 minutes - 2 hours
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
try SMC and PRAM resets. those solve most software related Mac problems. if SMC and PRAM resets don’t work then you might have to replace the trackpad.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad 이미지
상품
$59.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
mats.holmqvist 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 1,790
