주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Pro 15" Unibody Early 2011 Trackpad Replacement
필요한 것
    1. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
      • Three 13.5 mm (14.1 mm) Phillips screws.
      • Seven 3 mm Phillips screws.
      • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
      댓글 쓰기
    2. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 2 단계, 이미지 1개 중 1개
      • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
      댓글 쓰기
    1. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
      • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
      댓글 쓰기
    2. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 4 단계, 이미지 1개 중 1개
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
      댓글 쓰기
    1. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement, Left Fan: 5 단계, 이미지 1개 중 1개
      • Remove the following three screws securing the left fan to the logic board:
      • Two 3.5 mm T6 Torx screws.
      • One 4.2 mm T6 Torx screw.
      댓글 쓰기
    2. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 6 단계, 이미지 3개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 6 단계, 이미지 3개 중 2개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 6 단계, 이미지 3개 중 3개
      • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
      • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
      • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket.
      • The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
      댓글 쓰기
    3. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 7 단계, 이미지 1개 중 1개
      • Lift the left fan out of the upper case.
      댓글 쓰기
    1. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement, Logic Board: 8 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
      댓글 쓰기
    2. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 9 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board.
      • Lift the right fan out of its opening in the logic board.
      댓글 쓰기
    3. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 10 단계, 이미지 1개 중 1개
      • Pull the camera cable out of its socket on the logic board.
      • Don't lift upward on the camera cable as you disconnect it. Pulling upward on the cable may damage both the cable and the logic board. Pull the cable parallel to the face of the logic board.
      댓글 쓰기
    4. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 11 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
      댓글 쓰기
    5. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 12 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
      댓글 쓰기
    6. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 13 단계, 이미지 1개 중 1개
      • Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
      댓글 쓰기
    7. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 14 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
      • Pry up from beneath the wires.
      댓글 쓰기
    8. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 15 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 15 단계, 이미지 2개 중 2개
      • Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board.
      • Lift the cover off the logic board and set it aside.
      댓글 쓰기
    9. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 16 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
      댓글 쓰기
    10. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 17 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 17 단계, 이미지 2개 중 2개
      • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
      댓글 쓰기
    11. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 18 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
      댓글 쓰기
    12. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 19 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 19 단계, 이미지 2개 중 2개
      • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
      • Pull the display data cable straight out of its socket on the logic board.
      • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
      댓글 쓰기
    13. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 20 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 20 단계, 이미지 2개 중 2개
      • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
      • Be sure you are flipping up the hinged retaining flap, not the socket itself.
      • Pull the keyboard backlight ribbon cable out of its socket.
      댓글 쓰기
    14. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 21 단계, 이미지 1개 중 1개
      • Remove the following nine screws:
      • Seven 3.4 mm ( 3.1 mm) T6 Torx screws on the logic board
      • Two 8 mm T6 Torx screws on the DC-In board
      댓글 쓰기
    15. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 22 단계, 이미지 3개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 22 단계, 이미지 3개 중 2개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 22 단계, 이미지 3개 중 3개
      • Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
      • If necessary, use the flat end of a spudger to separate the microphone from the upper case.
      • Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
      댓글 쓰기
    1. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement, Battery: 23 단계, 이미지 1개 중 1개
      • Remove the two 7.5 mm ( 7.2 mm )Tri-point screws securing the battery to the upper case.
      댓글 쓰기
    2. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 24 단계, 이미지 1개 중 1개
      • Carefully peel the battery warning label off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
      • Remove the last 7.5 mm ( 7.2 mm ) Tri-point screw securing the battery to the upper case.
      • Do not remove the label from the battery.
      댓글 쓰기
    3. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 25 단계, 이미지 1개 중 1개
      • Use the attached plastic pull tab to remove the battery from the upper case.
      댓글 쓰기
    1. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement, Trackpad: 26 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement, Trackpad: 26 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger to peel up the edge of the large piece of black tape covering the trackpad cable.
      • Peel the tape up and fold it back out of the way of the trackpad cable. Leaving it in place on the upper case will make it easier to reapply it during reassembly.
      댓글 쓰기
    2. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 27 단계, 이미지 1개 중 1개
      • Open your MacBook Pro about 90 degrees and set it on its side on a table.
      • Remove the four silver 1.3 mm Phillips #00 screws from the trackpad spring brackets.
      댓글 쓰기
    3. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 28 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 28 단계, 이미지 2개 중 2개
      • While keeping a hold on the trackpad ribbon cable with one hand to keep it from tearing or creasing, ease the trackpad out of the upper case.
      • Move the trackpad back and to the right.
      댓글 쓰기
    4. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 29 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 29 단계, 이미지 2개 중 2개
      • Once the trackpad is free of the upper case, guide the ribbon cable through the slot cut in the upper case.
      댓글 쓰기
    5. MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 30 단계, 이미지 2개 중 1개 MacBook Pro 15" Unibody Early 2011 Trackpad Replacement: 30 단계, 이미지 2개 중 2개
      • When reinstalling the trackpad, loosely replace the four Phillips screws and check the alignment of the trackpad on the keyboard side of the upper case.
      • Once you have centered the trackpad in the upper case, tighten the Phillips screws all the way.
      • Use the large Tri-point screw at the bottom of the trackpad to adjust the click stroke.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 73명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Optimus Goldheart
회원 가입일: 10/17/09
515,490 평판
안내서 406개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 58,277개를 작성함
26가이드 댓글
Used this guide for a mid-2010 chassis, which seems the same. I'd recommend moving steps 23-25 to happen between steps 3 and 4. Basically, take the battery out first, immediately after removing the bottom cover. Also, replace it as a last step in reassembly prior to placing the bottom cover back on. What I found was that placing the logic board back into the machine (reversing step 22) was difficult with the fairly stiff battery connector cable. If you have better mojo than I do with a spudger, good on ya mate.
Nick - 답글 공유
Definitely follow the advice about battery out first and the tip regarding double sided tape and corrugated board is really good. Easy to follow steps and worked perfectly.
John Bannister - 답글 공유
Do I have to follow all the steps? My battery blew up; shattered the trackpad. Took battery out. Laptop works perfectly but need to replace trackpad. So since the battery is out, do I need to take everything else out, too? I do better with videos than still pictures. Dyslexia rules.
PB Ford - 답글 공유
Is it necessary to follow all the steps? My battery blew up; shattered the trackpad. Took battery out. Laptop works perfectly but need to replace trackpad. So since the battery is out, do I need to take everything else out, too? I do better with videos than still pictures. Dyslexia rules.
PB Ford - 답글 공유
I have followed the steps, now my keyboard and trackpad is not recognised by mac os............ i have checked the cables, everything is connected......
I'm fed up.
mbouchet42 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 75
전체 시간: 85,129
