주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Battery drains quickly after display unit replacement
Hi all,
after replacing the display unit of an iPhone 6, the battery drains very quickly. Just as an example, when the iPhone is used normally (no exceeding phone calls, no streaming, just checking mails from time to time), batterie goes down from 85% to 15% within 2 hours.
This was not the case with the cracked display.
Any thoughts and ideas here? Thank you very much.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Did the replacement screen come with a FCAM;/Sensor flex pre-installed? Some of these “complete” assemblies tend to have lower quality small parts and those are known to draw excessive current.
The first thing to try is to re-install the original screen and test for battery life. If it works normally, then either the replacement screen (LCD/Backlight) or the FCAM Flex is defective. If the original screen also has the same issue, then you may have damaged something during the repair.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Peter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 35
