주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
구글 픽셀은 2016년 10월 20일에 출시된 구글의 첫 번째 플래그십 스마트폰입니다. 5인치 AMOLED 디스플레이 장치에는 32GB 및 128GB 스토리지 옵션이 제공되며 베리 실버, 콰이트 블랙, 리얼 블루의 세 가지 색상으로 제공됩니다.
After Battery Replacement, Screen Won't Work
I swapped out the battery on a Pixel recently, I was careful about heating up the adhesive enough and used the plastic pick to sever the adhesive. The screen didn’t crack when removing it. After i got the battery switched out, I put everything back together and turned the phone on. The phone vibrated, indicating that it had turned on, but the screen is black. I was careful not to damage any of the ribbons when pulling it apart. Does anyone know what this might be?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
선택된 해법
The pixel has a very thin and fragile screen. It's very easy to damage the lcd without being able to see a visible crack. Also you could have knocked off components around the lcd connector. Or it could be a backlight issue. I would use a bright flashlight and shine it on the screen when you think it should be displaying and see if you can see anything. If you can then it's a backlight issue. If you have no backlight and no image then I would start looking at the board for damage. If you cant find any physical damage then I would get a new screen.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Whereabouts on the board would you check?
의
댓글 달기
Having the same issue with the Pixel 3. Changed the battery but did break a piece of did the wireless charger and the cable for the finger print scanner. I planned on replacing them eventually but in the mean time my phone won't boot up with the new battery. Won't even tell me it's charging. Having a hard time loading software and idk why.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I just changed the battery on my Pixel 4a. At first, when I pushed and held the power button, it would vibrate briefly, but the screen stayed black. I did that repeatedly- same thing. I thought maybe I had damaged the screen. When I held the power button for about 10 seconds (maybe longer), then the phone and screen finally turned on. Relief!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Robert Black 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 39
전체 시간: 4,404
