주요 콘텐츠로 건너뛰기
모델 A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 또는 3.5 GHz Core i7 프로세서, ID iMac14,2
340 질문 전체 보기
What do I do with the blade on a failing fusion drive?
I have a 27” late 2013 iMac with a failing (or rather failed) fusion drive. I would like to replace the HDD portion with a 2TB SSD. Do I need to remove the SSD blade? What happens in that case? Can I remove the SSD blade and not replace it? Right now I’m regretting I ever got the fusion drive. Thanks in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
A Fusion Drive is the marriage of a HDD and a SSD.
So at this point has your SSD part is failed or the HDD?
If the SSD failed it would make sense to replace it but I wouldn’t replace it with another small SSD and then redo the Fusion Drive. Instead I would setup standalone dual drive config where you use the SSD as your boot drive and leave your HDD as an independent data drive. While its a bit of work its worth it! iMac Intel 27" EMC 2639 Blade SSD Replacement It will give you the performance you really want. Here’s the SSD you’ll need Blade SSD.
If your HDD died then replacing it with a SSD while doable, can’t be joined to your blade SSD that was part of your Fusion Drive. The Faster PCIe interface of the blade SSD is ideal for your boot drive and holding your cache & paging files setup as independent dual drives.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Tom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 103
