주요 콘텐츠로 건너뛰기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
586 질문 전체 보기
Why is the new replacement battery not charging?
I ordered a replacement battery from iFixit and installed it. Unfortunately, the battery is not charging and my laptop can only remain on by staying plugged to the power cord. I reinstalled the old swollen battery and holds a charge for about 40 minutes before shutting down. Also, the light on the charger is green at all times when the new battery is installed and the old battery goes from green to orange to green once charged.
Is this a sign of the new battery being defected? I’ve done a NVRAM/PRAM and SMC reset with the new battery.
Thanks
Update (12/10/2018)
Attached are pics of the results.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
How was the old battery unplugged the first time? Was it with a metal pry tool by any chance?
댓글 달기
답변 3개
선택된 답변
As per your statics may be the ordered battery may have some issues and these issues can be treated directly by demanding a replacement battery from ifixit, if after doing NVRAM/PRAM and SMC reset with the new battery is not able to solve the issue and may be an issue with logic board
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
You don't have to demand anything, just ask.
@mayer Ok just ask for a replacement battery
댓글 달기
Hi Daniel,
What ended up happening? I JUST installed a new battery on a mid-2014 MBP from iFixit and I’m having the same problem!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
3rd party battery often draws more current then orignal one. I've tackled same issue on one laptop i received for repair. i checked entrie charging circuit on logic board but i didn't find issue….then i took cells from new battery and attached to original battery pcb and bammm it's done
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Daniel Venegas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 283
