주요 콘텐츠로 건너뛰기
Repair guides and support for 17" laptops in the Pavilion Notebook 17 series. These laptops have model numbers 17-g000 – 17-g099.
16 질문 전체 보기
질문 마감됨
Battery is not charging
Battery “47% (plugged in, not charging)” what do I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Ask a repair technician to check a power relay/controller. Can be that. Or the place that connects battery to MoBo, or paths between relay and battery.
All that is possible only if your battery isn’t discharging while your laptop is in use (be that work with docs or heavy duty like gaming/3D-modelling).
If your battery is discharging, then it might be an AC adapter issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Steps to fix a laptop battery that won't charge
Turn off your laptop. Turn off your device and wait 30 minutes before you turn it back on.
Check charging ports, cables, and outlets. Inspect your laptop's charging ports and see if there is any dust or debris.
Remove the battery.
Regards,
Rachel Gomez
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 426
