주요 콘텐츠로 건너뛰기
널리 사용되는 인기 Galaxy 제품 라인을 비롯한 여러 Android Samsung 휴대 전화, 구형 및 신형, 수리 안내서 및 분해도.
13180 질문 전체 보기
Why is my screen glitching?
We recently bought this phone and Dropped it causing the screen to crack. It worked well up in till it started glitching. This is what happened.
we could power it off and on but the screen just shows boxes and lines. We removed the battery but still nothing works. It does vibrate but it’s mainly the screen. There’s no water damage or Pressure.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
yes it is, unfortunately
댓글 달기
답변 2개
가장 유용한 답변
@emilyg444
your display is damaged. It may have worked well for a while until the LCD eventually failed. You need to replace it to fix this. It is not related to the battery or anything else.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
As we can see the picture, the display of the phone is completely damaged but the good thing here is there is no issue with the motherboard. Your phone functionality is still good. That’s the reason you are able to receive the calls and messages. But unfortunately you can’t see because of the broken screen.
I suggest you to contact the phone service center and get the screen replaced. Then it will work fine without any issues.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Emg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 1,650
