주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
293 질문 전체 보기
CPU Upgrade from i5 3.4 GHz to i9-9900k?
Hello Guys.
I need some help, I bought 27” iMac 2017. Which has Intel 3.4 GHz i5.
But my question is, is it possible to upgrade to i9-9900k or i7-9700k?
I would like to know if I can and I don’t want to damage my system.
I appreciate your comments, thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Simple Answer not possible!
The i9 CPU’s use a different socket (high heat) and the systems EFI (BIOS) doesn’t offer the needed firmware support.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Could you tell me which CPU could be work for that iMac? Thank you for your answer.
The top CPU in this series is the 4.2 GHz i7-7700K
iMac "Core i7" 4.2 27-Inch (5K, Mid-2017)
i7 7700k and i9 9900k share the same LGA 1151 socket. Probably it wouldn't work due to EFI restrictions or something.
댓글 달기
If you are in the SF Bay Area and have the CPU, I can rebuild the firmware. This is not rocket science. Man made machines should have ways to make them work. Never say no without giving a try.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
lopezclever 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,654
