주요 콘텐츠로 건너뛰기
Repair and support for the third generation of the Flip portable speaker by JBL.
70 질문 전체 보기
1r5 disconnected. Have to push down to make work .
I diagnosed that my 1R5 inductor is not detchted but loose. It seems I have to push back toward the wall to make the speaker work. But if I let go the speaker stops working. This was caused by a drop. I have a Jbl flip 3.
How do I keep the 1r5 to stay pressed down so my speaker works.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
hey austin,
as a general recomendation i would suggest to look if you can see if the connector to the main board is still correctly soldered in place and to see if you can solder it back on or replace the 1r5 if that doesn’t fix it just stay safe and good luck
-M
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
austin johnson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 486
