주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
휴대용 키보드에 부착하여 노트북처럼 사용할 수 있는 태블릿입니다.
bios not detecting hard disk
Ok, I have a Lenovo Flex 4 15" 2in1 laptop which I had two years but after the first year it would not fully load maybe because of connection, (maybe). Yes it will still power on. Now after some time I realized my Bios setup did not recognize are was not communicating with the hard disk . At first, thought hard drive was bad but it wasn't. Have anyone had this issue and can help me. Your help will be a blessing too me.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
When you turn on your computer, it show you a message like no hard drive detected ?
의
no just the name of my laptop
의
Have you tried to set default settings of the BIOS ?
의
when i go to bios it keep asking for password which i do not have
의
댓글 달기
답변 1개
가장 유용한 답변
Alternatively, you can try manual methods to fix this error, but if they do not help, then you need to change the Hard Disk.
Check the data cable
Check the Jumper Setting
Check for Auto Drive Detection
Check if the Drive is spinning
Generally, if the hard disk is not recognized by the BIOS, you have a hardware failure. For example, the Hard Disk is dead. In this case, you’ll need a new hard disk.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
WILLIAM WALKER 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 14
지난 30일: 35
전체 시간: 605
