주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Why my battery draining fast and phone gets warm
Why my ip 5s phone draining battery so fast even known good battery i think something shorted out the phone charges battery well but something strange when its turned off ,its not automatically boot when connected to charger i should push power button 1st then it detect the charge. Is it u2 defect symptom?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Has anything happened to the phone recently, such as a drop, repair attempt or water damage? Battery drain can be caused by a defective battery, broken charge circuit or defective peripheral (screen, camera, sensor, flex etc.) . Depending on the history of the device, it could be anyone of those causes.
If you have tried a known-good battery, then try a known good screen to see if that helps. If not, progressively remove peripherals until the problem is identified. Eventually, you may have only the logic board left which would point to a logic board issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I already tried changing battery,lcd,front camera flex,home button flex i will try changing port later
And why my iphone didnt turn on immidiately when it connect to power is it board issue?
댓글 달기
귀하의 답변을 추가하세요
azmi muwahid 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 56
