주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
My iPhone is overheating and draining at idle, battery replaced
Hello,
I’ve been having lots of drainage and thought my battery would just need to be replaced, however i replaced it and the problem still occurs!
ive attached my battery graph, my battery is brand new 100% capacity.
notice the bare usage and the drainage continues
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Has anything happened to the phone recently, such as a drop, repair attempt or water damage? Battery drain can be caused by a defective battery, broken charge circuit or defective peripheral (screen, camera, sensor, flex etc.) . Depending on the history of the device, it could be anyone of those causes.
If you have tried a known-good battery, then try a known good screen to see if that helps. If not, progressively remove peripherals until the problem is identified. Eventually, you may have only the logic board left which would point to a logic board issue.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I was told a faulty IC tristar can cause this issue, are one of the symptoms of a tristar to cause drainage?
Yes, that is one of the main symptoms. Another symptom could be phone dying before low battery even with a new battery.
Thanks guys! Turns out its the tristar IC.
댓글 달기
귀하의 답변을 추가하세요
Boudi Bazz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 925
