주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
I have hard drive problems, how to test drive to board cable
As title says hard drive problems, disc utility can't repair. I put it in an external dock and booted from install dvd and disc utility says all is well. This drive was brand new a month ago. I ran disc repair and am now in the process of installing os 10.6. If it installs, and it looks like it will, how do I test the hard drive cable and plug?
Thanks Walt
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
The only way to test the hdd cable is to replace it with a known good one and see if there is a difference.
Even a little shock can damage a spinning drive
you could try to erase the hdd and reinstall the os
You can find a hdd cable on eBay
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I did get the OS installed on the same hdd, so that's definitely not the problem. I used a usb hd dock and booted from the install dvd. It boots and works from external dock.
Although it loaded, it now has the dreaded beachball. It freezes with the least provacation. I opened activity monitor and it showed hardly any cpu activity, like a .6 for system. If I click anywhere else it freezes and I need to force shutdown. There is no hard drive internally so I'm guessing it is just too much for it through usb. I'm 99% sure the root cause is the drive cable so I'll do that as soon as I can. Hopefully that cures its ills lol.
댓글 달기
귀하의 답변을 추가하세요
Walter Lawler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 68
