주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
I ordered a screen replacement part. Trouble replacing it.
Hi,
I ordered screen replacement part. I don’t know why it has yellow overlay from inside.
Is it supposed to be glue, that needs to be melted or is it just an overlay?
My iphones screen is cracked and I want to replace it. But it is more complicated than I thought it is and I have trouble removing cracked screen piece from LCD.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Thanks for the answers. I did a little research. Yes it’s really difficult. Definitely the best option is to buy entire front screen with LCD and camera ect.
댓글 달기
답변 2개
선택된 답변
Peeling off LCD and re-bonding it on newer front glass is not DIY work. You will need professional equipment and skills, which can easily cost many times more than the phone itself.
The cheapest way is to glue the shattered screen onto a flat panel, get ultra thin wires, remove the side bezel, heat up the display the use the wire to cut from flex cable end, slowly cut the LCD off the front panel. The use adhesive solvent to clean the remaining adhesive.
Then you need professional fixture to align the LCD on replacement frame, then stick down the LCD. You will need a vacuum chamber to remove air bubbles, so I suggest you never do this on your own.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
The problem here is that you ordered just the glass without the lcd
Here is a list of missing equipement you need:
  1. LCD separator machine : $50
  2. Glue and Polarizer remover: $100
  3. Laminating and bubble remover machine: $150 to $1200 (depending on the scale of your business ;)
Or you can order one with the LCD already glued in from iFixit, eBay or Amazon
iPhone 5 Screen 이미지
상품
iPhone 5 Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Andre 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 52
