주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon Echo 2nd Generation 스마트 스피커는 2017년 10월 31일에 출시되었습니다.
My aux port doesn't work
I haven’t gotten quality speakers until a year later so the warrant just ended. I plugged in the aux cable for the first time and it doesn’t make any sound. It doesn’t really click in and instead just kinda sits there. It’s making a weak connection because the echo does recognize it’s connected if wiggled in the right position because it stops playing music at that moment. I think the aux port broke loose and needs to be repositioned or something similar. Is it possible to access the bottom of the echo and repair the aux port?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
It seems to me that in the Alexa app, then the device’s settings, you can change how the AUX port operates between in and output settings. As for the port being “loose” or out of line, it is soldered to the board making a replacement far more difficult. Not impossible, but my two cents would be to look for a replacement “AMP Board”. Hope this helps!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
2nd gen is only aux out not an input. Introduced on 3rd gen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
quinntensity 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 30
전체 시간: 2,773
