Inspiron 7460 lcd cable replacement
How to change the lcd cable of inspiron 7460 any manual ?
좋은 질문 입니까?
좋은 질문 입니까?
Hi @harvey1398 ,
Here’s a link to the service manual for your laptop, taken from this web page.
Scroll to p.34 to view the necessary pre-requisite steps and then the procedure to remove the display assembly.
Hopefully this is of some help.
해당 답변은 도움이 되었습니까?
It’s a fairly simple job. Here’s a video with a similar model: https://www.youtube.com/watch?v=dDD9C0-3...
But here are the steps:
Now it’s completely loose from the laptop and you just have to improvise a little bit and get the old cable out. Once it’s out, grab the replacement and put it in the laptop. From here just reverse the steps and remember to practice care when doing this as you don’t shock the motherboard. Touch something metal before grabbing any parts or components.
This may be a little off as the 7000 series is wide range of laptops with not a lot of documentation for each model. So if you have any questions feel free to ask.
해당 답변은 도움이 되었습니까?
When i opened the bezel im not quite sure which screw to remove and i think my laptop screen has also adhesive strip connected... base on my analysis my screen has only two screws holding it and two adhesives ill take a pictur of it if you want to
There will be two metal strips on the side of the LCD holding it in place. Those metal strips on both sides will be screwed into the back cover of the display assembly. Unscrew those and the LCD will come loose. Be careful not to let the LCD fall once unscrewed.
24 시간 전: 0
7일 전: 0
30일 전: 17
전체 시간: 538
