주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
Black screen on boot after replacing the top lid
I got this MacBook Pro Early 2015 model, The screen is messed up, it still displays picture just the right side is cracked. I ordered a replacement screen and installed it.
On boot its black no display. If I close the lid the Apple logo lights up, then I re-open the lid and the display is fine. If I restart with or without the power adapter it boots to a black screen. I tried clearing the PRAM and EMC. Same issue.
So i reinstalled the original screen and it displays the picture right away just like it should.
What am I missing?
Running Mojave
Update
I did that as instructed same behavior Here are 2 vids i just upload to youtube. I put the original screen back on. Took a video of it then Installed the replacement and took a video of it.
Oringal Screen: https://www.youtube.com/watch?v=zMoNKmnT...
Replacement: https://www.youtube.com/watch?v=a-zvgMXE...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 3개
Where did you get the display and the P/N you used? Also did you replace the full assembly?
Well, the part number is the correct one for your system MacBook Pro 13" (Early 2015) Display. But I think you got this one MacBook Pro 13" (Late 2013-Mid 2014) Display. Which explains why your display is not working correctly.
댓글 달기
답변 1개
가장 유용한 답변
Double check that these:
are connected properly. You can find the order in step 8 of this guide. Also double check the the LCD cable is connected properly to the screen. Sometimes if the connection isn’t solid this can happen. After all that power cycle the MacBook
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Can you get a replacement?
댓글 달기
귀하의 답변을 추가하세요
mikebarkas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 252
