주요 콘텐츠로 건너뛰기
Information and repair instructions for Electrolux Freezer
2 질문 전체 보기
AEG freezer not cooling down (temp 0-2), but fridge running
AEG/electrolux fridge-freezer
model s75388 kg9
serial 63640090
prod no 925033250-00
stoped freezing and temperature is at +2 (set at -18), fridge at +4. It seems to be constantly working with noise louder than normal. I unplugged for an hour, but still the same after half a day.
Appreciate any comments
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Add Coolent or contact the manufacturer
댓글 달기
답변 3개
가장 유용한 답변
Cause 1
Condenser Coils are Dirty
If the condenser coils are located within the freezer walls, the coils do not require cleaning. However, if the condenser coils can be readily accessed from behind or under the unit, you should clean them every 6-12 months. If the condenser coils are dirty, they won’t be able to dissipate heat effectively, greatly reducing the cooling capacity of the freezer. If the condenser coils are dirty or have not been cleaned in a while, clean them.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan motor is not working, the freezer will not cool. On most refrigerators, the fan motor will not run when the door is open. To check the evaporator fan motor, open the freezer door and then manually activate the freezer door switch. If the door switch is activated, but the evaporator fan motor won’t run, replace the evaporator fan motor.
Parts
Cause 3
Start Relay
The start relay provides power to the compressor. If the start relay isn’t working properly, the compressor may run intermittently or may not run at all. If the compressor won’t run, the freezer will not cool. To determine if the start relay is defective, unplug the freezer and remove the start relay from the compressor. Use a multimeter to test the start relay for continuity between the start and run terminals. If the start relay does not have continuity, or if it smells burnt, replace it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Add coolant or contact the manufacturer
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had this problem just now. I opened the panels inside the freezer. This coils were frosted up. Took a hairdryer and warmed up the ice. Fridge side is cooling now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi ,
Yes but why did the evaporator unit ice over if the fridge has an auto defrost feature?
You may have a faulty defrost heater, defrost thermostat or control board.
What is the make and model number of the fridge?
댓글 달기
귀하의 답변을 추가하세요
crazy_diamond1984 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 26
전체 시간: 5,039
