주요 콘텐츠로 건너뛰기
Repair guides for feature cell phones manufactured by Kyocera. This category is for phones not using an Android or Windows operating system.
26 질문 전체 보기
How to replace the battery of the Kyocera Hydro Shore model C6742A?
I cannot find a guide or tutorial on how to take apart the Kyocera Hydro Shore model C6742A. The back place looks like a solid piece with the glass possibly glued in, there are some screws but not the typical ones. Those holes from previous models are filled in plastic, and the 3.5mm jack has 3 screws, and there’s a screw over the power button once the back cover plate is off, but the space where the battery would be is solid plastic with the back plastic part of the phone itself. Do we have to heat this screen up to remove it from the plastic? are there any ribbon cables to be aware of? Can anyone please post a guide or knowledge of how to take apart this phone?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Here’s how AT&T says to do it:
https://www.att.com/devicehowto/tutorial...
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hi @mayer ,
I think that the "tutorial" is incorrectly named.
It should be "install and remove the SIM card and the SD Card"
There is no mention at all about how to replace the battery.
Happy New Year
Cheers.
@jayeff you are correct, they have nothing on replacing the battery
댓글 달기
귀하의 답변을 추가하세요
sageman98 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 672
