주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
MacBook Late 2006 boots to white screen, but works on external monitor
I recently swapped the display in my Macbook Late 2006. It was cracked and I found a cheap working display on eBay . The Macbook boots okay but the display remains white. I connected an external monitor and the Macbook works fine with that.
Do you think it’s a faulty display?
Or is it possible I have connected the display cables incorrectly?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sounds like you got the wrong display assembly. While they look the same they are not the same!
MacBook 13.3" Core 2 Duo Display Assembly 이미지
상품
$299.99
MacBook 13.3" Santa Rosa/Penryn Display Assembly 이미지
상품
$299.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Ok thanks. I’ll have a look.
Is there a way to check the display part number from System Profiler or using an app?
Plug in your systems S/N into here EveryMac - Lookup it will tell you the exact model you have as they both look the same.
Basically, the Intel graphics services (Intel GMA X3100 & Intel GMA X3100) is what defines which display is needed. As the signaling is different enough that each needs a unique display assembly.
댓글 달기
귀하의 답변을 추가하세요
Matt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 53
