주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Restore Oleophobic coating / scratches in my iPhone X
Hi there :)
I thinking to restore my light scratches in my iPhone X
I’ve purchased this ——-> www.ebay.co.uk/itm/113299806177
I wish to know “the worst scenario” - like it will remove “Apple coating” and apply…… worse one?
Do You know any good Oleophobic coating liquids?
I know other one made by Fusso - but it is 10 times more expensive - I don’t want to spend too much money.
Many times it is the same chemical inside - just different brand and better looking packaging.
P.S. What are “ingredients” those Oleophobic coatings?
Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi
I understand the scratch thing but have you tested the screen to see if the Oleophobic coating has worn off ? You can do that just by putting a single drop of water on the screen, if it stays almost in a sphere shape then it hasn’t worn off. If it just splats onto the display and does not form a sphere then the coating has worn off. You have two options. The first is to do what you are doing with the product you have bought or you can put on a high quality screen protector, the more expensive ones usually have an Oleophobic coating of their own.
If the coating has worn off and you wipe on a new one I doubt it would make the screen worse but just remember that when its done at the factory its baked on after its applied and normally lasts one to two years. If you re-apply it yourself it may only last a few months and will need to be done again.
The chemical makeup according to the patent made by the inventor at 3M is as follows :-
“Hydrophobic and oleophobic coating composition, which comprises the following components based on weight percentage: 0.1-15% of a fluorosiloxane, 1-30% of a polyacrylic resin, 0.1-15% of a silane coupler, 33-98% of an organic solvent, and 0.05-15% of an acid.”
Personally I would go for the screen protector, but give the product you have bought a shot and let us know how it goes.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
soooo - that purchased product SUCKS - basically it is like....... stinking water - which do NOTHING.
And I'll go further - I did not expect to remove deeper scratches - I was hoping to remove those MICRO scratches - but again - it did NOTHING.
It might work on car body - but no on iPhone X 64GB screen.
anyway - it was cheaper for my to sell it for £430 and purchase 256GB for £400 with better screen
How to Restore or Apply an Oleophobic Coating
If you follow the guide here, you can restore the oleophobic coating.
You should not trust cheap chemical products from ebay.
The product from the guide will create an oleophobic layer. However, it is not possible to remove scratches!
Why not just purchase a good full coverage screen protector with oleophobic coating?
This hides most minor scratches on the screen.
댓글 달기
귀하의 답변을 추가하세요
Bart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 2,017
