주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Light veritical streaks on my new screen - is it busted?
I just replaced my iPhone SE screen with an iFixit replacement. I did a quick check when everything was plugged back in, but the screen & case NOT snapped back together, and it all looked great. But after snapping the case back together, I now have light vertical streaks on the display! Otherwise, everything seems to work fine (home button, ID, camera, etc.).
I re-opened the case, disconnected the battery and display connectors, re-connected everything, and re-tested - same result. . . TWICE! arrrgh!
So, did my new screen somehow get broken, or is there another possible cause?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
The flap you are referring to is the small metal prong that kind of clips into the display.
There are two prongs that go over the earpiece speaker to hold the front camera and speaker in place which is also held in with two screws.
The right prong clips into the display and the left prong also does the same, but that one must be put in properly or it can pierce the display cable.
It could be that when putting the screen into place it may have been put in with too much force.
As long as the corners of the iPhone's metal housing is not dented inwards where it could make it difficult for the screen to go in.
It should be fine while taking note that the screen hooks in from the top first then bit by bit work your way down pushing it into place while applying a bit of upwards pressure to make sure the screen is pushed towards the top to make it easier to clip in as you'll be doing the bottom last.
Once it pops all the way in it should have no problems, it sounds like a defective screen.
Sorry about the long paragraph but that is my experience from doing iPhone 5 series screen replacements over the years.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Behind the aluminum shield, at the top there is a flap that runs down, it is part of the flex cable for the earpiece, make sure that it is behind the shield, not in front.
At the top, where the red film cuts off in the middle, there is a flex cable, that if you leave outside and on top of the metal shield, it will cause interference.
해당 답변은 도움이 되었습니까?
점수 1
댓글 9개:
Hi - Thank you for the advice, but please clarify:
1. The flap that should be "behind the shield," are you referring to the large shield that forms the back of the display, or the small shield that screws down over the display connectors? If it's the large one, does "behind" mean sitting on top of the shield when the display is face down, which will put it between the shield and the rest of the 'innards' when it's put back together? (To me, "behind the shield" sounds like it's tucked between the shield and the display/digitizer...unless, of course, you mean the small shield.)
2. The phone is not apart right now, but I don't recall a "red film " and I don't see one in the photos. Can you clarify?
Large shield behind the LCD. Not the one that screws over the connectors. The flap I'm talking about is right where the cut out is for the red plastic film on the top under the earpiece. That film doesn't stay on, I was just using that as a reference point.
You want to ensure that the flap is tucked in beneath the LCD and the Metal LCD Cover.
I also cannot find a good picture to reference of what I am talking about, let me check ifixit.
But when the LCD is closed, this flap should not be between the innards of the phone and LCD shield, it should be in between LCD and LCD Shield.
댓글 4개 더보기
댓글 달기
Apparently, it was a bad display after all. When I installed a replacement, everything was perfect!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Glenn Richards 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 70
