주요 콘텐츠로 건너뛰기
Third generation Surface Pro tablet, released June 20, 2014.
123 질문 전체 보기
Testing a Surface Pro 3 battery that has been removed.
How do I use a volt meter to check the battery ? It is disconnected from the motherboard but there are no obvious pos and neg points. The cable appears to split internally in to 2 halfs.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi John,
I am hypothesizing that the two halves are the main positive and negative terminals. Which one's positive, I'm not sure but it will just show up as negative voltage on your meter if swapped. I'm guessing the small traces near one split is either for sensing or individual cell charging.
BE CAREFUL not to short the battery with your leads!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
John Macauley 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 137
