주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Do replacement batteries work with battery health feature now?
There is a ton of mixed info about this. Older posts state that battery health doesnt work with aftermarket batteries, yet some people post that newer batteries now support this feature. I am thinking about ordering a replacement battery for iPhone 6 and am curious if the feature will work or not.
If it doesnt work, then is there any way to tell if the phone is throttled other than running a benchmark?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
This question was migrated from https://www.ifixit.com/Answers.
This question was migrated from https://meta.ifixit.com/Answers.
댓글 달기
답변 2개
가장 유용한 답변
You’re right, the feedback is mixed, and it’s because iFixit batteries are not 100% reliable on this yet—whether or not the battery health feature will work depends on your exact model iPhone, which iOS version you have installed, and the battery’s internal firmware version. We’ve developed a long-term solution that should work for all batteries on all past (and future) versions of iOS, and it’s making its way out over the next month or two. So if you want the battery health feature and you have the luxury of waiting a bit, you may want to check back in February or March.
To your second question: the phone is only throttled if the battery is unable to supply the needed voltage. So yeah, running benchmarking software like Geekbench is a great way to verify that everything is ship shape.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It depends on the battery, some aftermarket ones fail to show any battery information but function. You can see this if it doesn’t show battery info on both 3UTools (Windows application downloaded from 3u.com) or Battery Health in settings.
If you only have a Mac you can use CoconutBattery app instead.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I am curious specifically about the iFixIt iPhone 6 battery.
OK so on their product page their aftermarket batteries do not support the battery health feature meaning there will be no battery health measurement when you try to use the battery health feature.
Yes I saw that, but some people reported that with iOS 12.1 it worked for them. So I am wondering if the info is outdated? I was looking for someone who did a swap recently to chime in with their experience.
댓글 달기
귀하의 답변을 추가하세요
Andrei 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 26
전체 시간: 1,134
