A 2.8v battery of Ipad Mini 1 still good?
Hey guyz how do I know if an old ipad mini 1 with 2.8v charged battery still good? The new battery reads 3.0v.in multimeter.
좋은 질문 입니까?
좋은 질문 입니까?
Depends, you'll need to charge it for quite a while to turn it on 3.7V is minimal voltage to boot an iPad up and 4.1-4.4V is maximum charge voltage for battery.
You can use 3Utools from 3u.com on a windows computer once you got the iPad on to check the battery health.
해당 답변은 도움이 되었습니까?
If you have a Mac, you can use Coconut battery to check out your battery by using your charging cable and plug into a USB port. It has an iOS feature that will check both iPhones and iPads.
해당 답변은 도움이 되었습니까?
Ipad mini is dead
Some kind of logic board problem i just thinking to reused the battery.
You really don't want to reuse a battery you've pulled. You can easily cause damage during the removal process that would make the battery unstable in a new device.
If the battery voltage drops below certain threshold, it will lock out and refuse any charge, this is a safety mechanism by design.
However I’m not sure if 2.8 is the threshold or if there is anything else wrong with it.
해당 답변은 도움이 되었습니까?
Just download a app that will tell you the health of your battery you don’t need to manually test the battery. Just search up battery life in the AppStore
해당 답변은 도움이 되었습니까?
I can't do that because my ipad mini is tottaly dead.
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 96
