주요 콘텐츠로 건너뛰기
3 MB 공유 L3 캐시 1.7 듀얼-코어 Intel 프로세서 (Turbo Boost 최대 2.6 GHz).
139 질문 전체 보기
Help - MacBook Air 11" Will not charge after new battery replacement
Started out one day I had MacBook Air on charge went to pick it up and the battery had malfunctioned and swollen up. Easy fix I thought to remove pressure and any damage to the case and internals I removed the battery while I sourced a new replacement.
The MacBook was still fully functional on charger without the battery the charge LED is green. New battery tuned up installed and charger showing green but system not showing any battery installed under system report or in top menu bar.
Suspected faulty new battery so supplier sent another new boxed one, but same symptoms. Charger LED green, system information and top tray not showing any battery present. Going into settings turning on “show battery status in menu bar” its shows up for a second then disappears.
Looking for any help on what parts if any to replace next, have also tried second spare charger same result. The laptop works fine on charger but remove charger and it isn’t taking power from he battery and turns off immediately.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
No one can tell what’s the issue, without some logic board testing we are in guess land..if you want to try and do the job yourself it would be reasonable to attempt replacing I/O board and relevant connecting cable. These are the parts you would need:
MacBook Air 11" (Mid 2012) I/O Board Cable
MacBook Air 11" (Mid 2012) I/O Board Cable 이미지
상품
$19.99
MacBook Air 11" (Mid 2012) I/O Board 이미지
상품
$49.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Wrong model battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Confirmed it seems to be direct replacement for the one that was removed.
댓글 달기
귀하의 답변을 추가하세요
Scott Lawson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 113
