주요 콘텐츠로 건너뛰기
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 질문 전체 보기
What is the part that should be replaced if the display is flickering?
My Ipad mini model is A1432.
After I had left it idle for 1 year and got it back to use a month ago, the display has been flickering like ghost touching as the video posted underneath shows.
If the brightness level is low, the flickering becomes more serious. The lower, the more serious, vice versa.
Flickering when brightness level is low:
https://www.youtube.com/watch?v=KZlUyVAc...
Flickering when brightness level is high:
https://www.youtube.com/watch?v=ytaX8ANv...
In this case, if I want to repair it by myself, what is the component that I should replace?
Is it the LCD screen? It is good if anyone could provide a pic of that particular part.
Would I get to know better which part that I should replace after the Ipad is opened? Is there any detailed guide that I can follow for checking?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Thanks for the reply and the guide.
Suppose I want to replace the LCD screen, how do I stick back the front panel after the adhesive glue is undermined?
Is it possible to just plug it back and use the tablet as usual without applying any extra glue?
You need to remove any adhesive residue and apply a new strip of adhesive on front panel for it to adhere to the aluminum frame.
Pre-cut adhesive strips can be bought from various retailers online or in store, google "iPad mini adhesive strips"
Thank you for all the replies. It is the LCD problem and I have already replaced it. My gadget works perfectly fine now. Umm... I am eternally grateful.
댓글 달기
답변 2개
선택된 답변
Based on your description, most likely the LCD screen has gone bad, but there lies the possibility of a logic board related issue too.
You need to open it up and troubleshoot with a working LCD, if flickering issue still persists with replacement LCD, then you need to take it to a reputable repair shop, as the component level repair is not DIY friendly.
Repair guide on replacing LCD on iPad Mini:
iPad Mini Wi-Fi LCD Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
The links don’t work so I can’t say for certain.
Ghost touching is caused by a bad digitizer. This is the repair guide to use to change it yourself.
Image flickering could be caused by a damaged LCD. The repair guide for the LCD Replacement is here.
The iPad mini also has really weak connectors for the digitizer and to a lesser extent the LCD. You’ll want to closely inspect those before ordering any parts. I would take apart the iPad (you have to get the digitizer AND LCD off regardless of what you end up changing) and closely inspect the connectors. Then determine what you need to order.
iPad Mini Wi-Fi LCD 이미지
안내서
난이도:
어려움
2 - 3 hours
iPad Mini Wi-Fi Front Panel Assembly 이미지
안내서
iPad Mini Wi-Fi Front Panel Assembly Replacement
난이도:
어려움
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
liam cage 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 229
