주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 출시된 Asus N76VZ는 1600x900 픽셀 또는 1920x1080 픽셀 화면 해상도를 갖춘 17인치 노트북입니다. 3세대 Intel Core i7 프로세서와 Nvidia 그래픽 카드가 탑재되어 있습니다.
Why can't remove battery
Hello
I am trying to remove battery on Notebook Asus N76V, but I think it have problem with the slider lock because he is on the wrong position and now it is very hard to remove it, I tried a little force to remove it but I wasn’t able to do it… I searched many solution but I didn’t found the solution.
Edit: it is Asus N76VJ but I think it’s the same way to remove battery.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
It’s likely that the slider to unlock the battery is broken. First try sliding it to the unlocked position and force the battery out. There isn’t much you can do other than replacing the bottom case. I’ve found though that a lot of times if I force it out, it will come out with little damage.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
with flat head screwdriver,
start to lift battery pack from back ( furthest away from battery open slider )
start to lever from right or left ,,, lever from either corner
This worked for me and i did no damage to mechanism
operate lever and apply some silicon spray
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
This was actually helpful!
I used a plastic pick and started wiggling and sliding.
I spent more than 30 minutes trying before seeing this tip, and I was so happy that I didn't break anything lol
Thanks
의
댓글 달기
답변을 추가하세요
Mickael Gomes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 1,424
