주요 콘텐츠로 건너뛰기
12.1 MP camera with 3x optical image stabilized zoom. Released February 2009.
4 질문 전체 보기
Canon SD780 IS service manual?
Anyone knows where I could get the service manual or a take apart guide for the Canon SD780 IS ? I need to replace the flash unit on this one.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 6개
선택된 답변
This is what I was searching for:
http://www.youtube.com/watch?v=B4GGhTTN1...
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
cant locate a manual so far but THIS may help you.
If you do take it apart perhaps you can start a guide here at iFixit
Also there are many similarities between models so THESE existing guides may be useful
HIH
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
thanks for the links Richdave.
댓글 달기
There are several websites that have the owners manual. Here are some:
http://gdlp01.c-wss.com/gds/4/0300002064...
http://www.lib.jmu.edu/media/documents/C...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Mark Thompson, the OP was wondering if "I could get the service manual", not the owners manual 2 1/2 years ago:-)
댓글 달기
Look here: http://www.smpcshop.com/Canon-PowerShot-...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
thanks a lot
The top-end successor to the IXY DIGITAL 210 IS released in February 2009, the 220 IS features not only a an expanded 2.7-inch Clear Live LCD II monitor and newly designed 4x zoom lens that supports wide-angle 28 mm* shooting for increased lens power, but does so while maintaining a slim body measuring 20.0 mm thick. The model’s smooth, stainless, and sleek exterior comes in four different color variations.
http://www.canon.com/camera-museum/camer...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
When using an Eye-Fi card with the Canon PowerShot SD780 IS / IXUS 100 IS / IXY 210 IS, it is best to adjust the power settings so that the camera does not turn off before transferring has finished.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
lemerise 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 3,457
