주요 콘텐츠로 건너뛰기
모델 A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 또는 3.5 GHz Core i7 프로세서, ID iMac14,2
340 질문 전체 보기
Late 2013 iMac (27") screen hinge replacement
Does the iFixit forum have their own version of a full step-by-step guide to fixing the broken hinge issue with the late 2013 27” iMacs? I am not looking for a machack fix where you are required to fit an additional clamp between the screen and the stand. I would like to fix the hinge so that the tilt can operate as it should. But at the same time, I do not want to take it to Apple only to be charged an exorbitant price.
Thank you guys!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
The steps are the same as taking the logic board out. Review this IFIXIT guide iMac Intel 27" EMC 2639 Logic Board Replacement once you get to that point you can see the hinge which is just behind it
Take the foot stand off (nine screws) as well as the stand and then take the hinge its self off. The replacement hinge info: The Book Yard UK - Mac 27" Hinge/Clutch Mechanism (12/13) Apple P/N 923-00151
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
And just to add there is no need to replace the entire mechanism, the issue is caused by the rubbish plastic washers that secure the end of the spring mechanism. You can replace these with metal ones to fix the issue and prevent it recurring.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I used a coil from old logic board…
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Wayne H 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 4,044
