주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
265 질문 전체 보기
installation of Airport / Bluetooth card did not work
Recently purchased and intalled Airport/BLuetooth card on my MacBook Air Retina late 2012 model. Everything went smoothly but I get “Device Hardware Not Installed” when booting.. I’ve tried all the web tricks (resetting power, etc),, but I think my problem might be elsewhere in the cable or antenna?
Question is do you have other components that I could try?
If no, can I de-install and return the card for refund?
Thanks,
Mike
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Hi Dan, here is the "About this Mac" info.. thanks for helping
MacBook Pro
13" retina, late-2012
2.5Ghz intel core i5
8GB 1600mhz DDR3
Intel HD Graphics 4000 1024 MB
댓글 달기
답변 1개
First this is an open blog where volunteers help people with hardware questions. This is not the stores Storefront. If you need to return the part you’ll need to contact them Contact iFixit Customer Support
Updated
Are you sure you got the correct one? MacBook Pro 13" and 15" Retina (Late 2012-Early 2013) Airport/Bluetooth Board
Often times I find the cable also needs replacing MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable and sometimes MacBook Pro 13" Retina (Late 2012-Early 2013) Right I/O Board
MacBook Pro 13" and 15" Retina (Late 2012-Early 2013) Airport/Bluetooth Board 이미지
상품
$49.99
MacBook Pro 13" Retina (Late 2012-Early 2013) Right I/O Board 이미지
상품
$49.99
MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable 이미지
상품
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Dan
Thanks for the advice and I’ve since reached out to customer support. The board you showed above doesn’t appear to be the right one.. the one I got was an exact physical match to the one I took out (so I think its correct).. as a last resort I’m trying to see if there is a cable or antennae component that could be the problem. I’m kind of assuming the board is fine at this point. Given the availability and low cost of external wifi devices, I am leaning towards returning the board and getting a small external wifi device instead.
Regards, Mike
You supplied conflicting information on your system. How about clarifying which size 11" or 13"
댓글 달기
귀하의 답변을 추가하세요
Mike Phillips 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 93
