주요 콘텐츠로 건너뛰기
2009년 3월에 소개된 The Mac Pro (Early 2009)는 Intel Nehalem 아키텍처를 Apple의 전문가용 데스크탑 라인에 도입하였으며 미묘하게 재설계된 내부는 2010 및 2012 CPU 업데이트를 통해 소개되었습니다.
201 질문 전체 보기
Database folders in trash every 30 minutes
I keep getting a folder labeled database in my trash every 30 minutes that has 2 SQLite files inside. Don’t really know how it started or where it comes from but I need help to stop it. I have know clue as to where the folder is being delete from or what type of database it is. I just get them every 30 minutes in my trash. Searched the web and no one seems to have an answer or solution for the problem. Contacted Apple support and they had not a clue or answer for what it is or how to stop it. It seems to be a common issue but no one seems to have an answer that will correct it. Need help please.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
SQLite is a compact, cross platform, self-contained relational database management system that is available in the public domain. SQLite is included in macOS and Mac OS X by default. It is located in the /usr/bin directory and called sqlite3. ... With RazorSQL, users can create new or edit existing SQLite databases.
Here is a discussion of the issue and it may be related to RSS feeds on Safari and mail. There are a couple of solutions to try here.
https://discussions.apple.com/thread/120...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Click on your user name on the right menu bar > Users & Groups Preferences… That will open the control menu. Click on the Login Items to see what apps are auto loading delete any ones you don’t want to auto load.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for your response but it didn't help.
댓글 달기
귀하의 답변을 추가하세요
Tephen Dumas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 105
