주요 콘텐츠로 건너뛰기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
418 질문 전체 보기
Replaced GSA-S10N will not burn discs
I replaced a clients SuperDrive in their A1181 with a brand new GSA-S10N SuperDrive (it's stated on this site that this drive will work in this machine). Other than it being louder than the original drive (are they usually?) it played CDs, DVDs and read discs just fine. We returned it to the client and collected for the job. 3 days later the MacBook was returned to us as the drive still played/read disc but it would not burn CDs or DVDs at all. Out of iTunes the disc wouldn't even make it past the initialization stage and would return a "medium write error." What are we missing here?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
Have you tried different brands/types of media? I recently came across a 50-pack of CDRs that were ALL bad, I assume due to a manufacturing defect, so it is possible that the media is bad, especially considering it reads fine.
If you've tried burning different types and brands of media and it still doesn't work, there's not much to say but that the drive is probably bad. It may be worth trying to burn at a slower speed, but then again it doesn't make sense that iTunes would be giving you problems. A lack of RAM can lead to burning problems, but you've got a MacBook, so I assume you've got at least 512MB, which should be enough to burn out of iTunes. I'd also try burning out of another application such as Toast, or even in the Finder, just to verify it's not any one application.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
We did try some different brands. I'm thinking it may have to do with the version of OS X the client is running. Could this be a possible issue? I'm going to do a further software/OS diagnostic tomorrow to see if this may be the case.
No, the version of the OS shouldn't matter at all. All versions of the OS that a MacBook will run should be fine burning CDs and DVDs. I would make sure the machine is fully patched, but whether it's running Tiger, Leopard, etc., should make no difference. To avoid confusion I'd put in a blank CD and try doing burning in the finder rather than in iTunes or other apps which could conceivably cloud the issue. If it fails in the finder, and other apps, and you've tried different brands, you can probably rest assured there's a hardware issue.
Well upon further testing it will burn a DVD in Finder, but will not burn CDs at all. Going to try to delete the file com.apple.DiskUtility.plist in ~user/Library/Preferences and see what happens. It may just be a hardware profile issue.
댓글 달기
귀하의 답변을 추가하세요
Lewis Feinman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,465
