Trying to repair my LW3000PLUS generator
I can onlyget it to run for a short time on starting fluid…is there a guide or manual for it available??
좋은 질문 입니까?
좋은 질문 입니까?
I’m not familiar with this unit But I can almost guarantee that it is a gummed up Carb. If it sat for 4 months or more without fuel additive, The jets are clogged & the carb. needs to be cleaned in a ultrasonic cleaner by a professional w/ a few new parts. Please don’t try a Chinese Cheap Carb. off EBAY. They never work.
해당 답변은 도움이 되었습니까?
The alternator is an electrical equipment that has a very complex design. If it is broken or fails, the battery charge is completely absent, and the engine stops functioning. Therefore, trying to repair the generator with your own hands is best. This requires only a minimum of knowledge in electrical engineering and the presence of a soldering iron and skills to work with it.
If you are experiencing difficulties, you can call a master for repair or buy one of the dual fuel generators. Good luck to you!
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 6
30일 전: 12
전체 시간: 90
