주요 콘텐츠로 건너뛰기
Samsung의 주력 스타일러스 휴대폰은 2018년 8월에 출시된 Note8의 후속 모델입니다. 6.4” 스크린 및 최대 512GB의 온보드 저장 용량이 특징입니다.
104 질문 전체 보기
Touch screen recognizing finger only s pen on note 9
I was replacing a screen on a note 9 and when I switched the motherboard and other components to the new screen and powered it on the phone would not recognize me touching it with my finger so I tried the s pen and it worked fine so then I switched everything back to the old screen thinking that it was just a defective part and it still wasn't working. I tried cleaning off the connectors for the screen and resetting the phone and neither worked. Any help would be greatly appreciated. Thank you in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
I thought so too but I put all the components back onto the original screen and the touchscreen didn't work on there anymore and I also tried different screen and didn't work on there either
댓글 달기
답변 2개
가장 유용한 답변
probably just a faulty screen
S pen is a completely different part of the display to the digitizer, it’s the large rectangle flex near the lcd connector.
unless you buy the screen from samsung or from a new phone they are all refurbished, so probably just a dud screen
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Did you ever get this fix? I'm having the same
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Also, would something like that be under warranty?
댓글 달기
귀하의 답변을 추가하세요
Poop mcgee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 2,302
