주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Braun 면도기 수리 안내서.
Razor not turn on
Cruzer5 charges but does not turn on
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Hi @tamandy239 ,
Does it turn on when the charger is connected and switched on?
If it does then the batteries may be failing to hold their charge and need to be replaced.
If it doesn’t then there may be a problem with the on/off switch etc.
In any event the razor will need to be opened and inspected as to what the problem may be.
Here’s a link to a video that shows how to dis-assemble the razor.
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
The video is private, I can't view it.
의 공유
@ハッサンモハメド
Try this one
의 공유
댓글 달기
Make sure the razor is charging correctly. It is a common mistake to see the solid green light on the charger, but it also requires the flashing green light on the razor itself.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Andy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 37
지난 30일: 136
전체 시간: 23,223
