주요 콘텐츠로 건너뛰기
Device repair and information for the Dell Alienware 15 R3, a gaming laptop in the Alienware series.
14 질문 전체 보기
Why is my laptop fans making a weird buzzing noise?
I am pretty sure the fans are dusty, I try to blow them with my mouth but certainly that doesn’t solve anything. I’m currently travelling so I Dell’s support can’t reach me. And I don’t trust the surrounding shops with my laptop.
I think I have to do this myself but is it really dust?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @metachii ,
It may be dust but it could also be a faulty fan.
Here’s a link to the service manual for your laptop.
Scroll to p.71 to view the necessary pre-requisite steps and then the procedure to remove the heat sink/fan assembly. (depending on the specifications of your laptop, you may be able to remove the fans without removing the entire heat sink assembly).
This should allow you to check if it is dust or a faulty fan (bearing perhaps?)
If you need to replace the fan or heatsink fan just search online for Dell Alienware 15 R3 fan to get results for suppliers.
If the laptop is still under warranty it may be better to consult Dell regarding the problem as you don’t want to void the warranty by opening it yourself. You may have reason to use the warranty in the future ;-)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Metachii 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 18
전체 시간: 1,726
