주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임기입니다. 2017년 3월 3일 출시되었습니다.
Controller Doesn't Work Properly!
Every time I use the switch one of the controllers make the game move without my input. Along with that many buttons don’t work at random times. How do I fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Those two symptoms together are a useful clue: movement without input usually points to a drifting stick, while buttons that fail only at random times usually points to a connection, seating, or button-contact problem. Test them separately instead of treating the whole controller as one fault.
1. Find which controller is at fault. Test each controller on its own, in the same game, and note whether the unwanted movement and the dead buttons always come from the same controller. If only one controller is affected, do not replace or open both.
2. Rest test and deadzone check. Leave the sticks untouched in a menu and watch whether the game moves on its own. Then move each stick slowly through its full range and let go. If movement always drifts in one direction, or the stick does not settle at centre, that is drift, not a game setting.
3. Reseat, clean, and recalibrate. Detach and reattach the controller firmly, clean the rails and contacts carefully, and run the system's controller calibration. Then test again in a second game. If the problem follows the controller to another game, it is in the controller, not that one title.
4. Test every button and stick on a PC if you can connect the controller by USB or Bluetooth, thentest your controller online, and press each button, move both sticks fully, and squeeze both triggers. If a button registers on a PC but not on the Switch, the fault is more likely seating or a Switch-side setting. If the same button fails everywhere, its contact or membrane is the suspect.
5. If drift remains after cleaning and recalibration, or a button fails consistently in every test, the stick or button assembly needs repair or replacement. Do not keep forcing a sticking button, as that can damage the contact further.
Disclosure: I run this free tester.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mr A 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 131
