주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Series 5 3G Chromebook. 이 노트북은 웹 브라우징에 이상적인 12.1인치 Super Bright 고해상도 비반사 디스플레이를 갖추고 있습니다.
Where's Developer Mode Switch?
The Developer mode switch is supposed
to be in the battery compartment or
behind a removable panel.
It's a very important feature and you
don't mention it all. where is it
located at?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
mine was a device that had no switch near the sim , instead it was inside the small hole in the case to the right of the power button
의 공유
댓글 달기
답변 3개
선택된 해법
The dev switch is accessable without opening the device. It is on the right hand side of the device behind the SIM slot cover.
Edit: You can see it right below the SIM slot on the Step 14 teardown picture.
이 답변이 도움이 되었나요?
점수 5
댓글 2개:
I Have a chrome book and have looked behind the panel where it is supposed to be and there is not a switch there, the hole is but there is not a switch to use?
Any ideas?
의 공유
robert clench, did you confirm this by checking the image of the teardown?
의 공유
댓글 달기
From what I've read, the developer switch is only on the CR-48 (Prototype/Developer Chromebook) It isn't found on retail models.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Not according to what's stated in here. http://goo.gl/b2Fl2
Shell access is only available in Dev mode, if it's not included, a lot of people are going to be angry.
의 공유
댓글 달기
The Dev Switch Is On The Right Side Of The Unit, Where The Sim Card Slot Is Located, It's A Switch That Can Be Toggled With A Pin (Paper Clip) Or The Tip Of A Pen.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
So you are confirming what "no way" answered in June of 2011 correctly. Good Job ;-)
의 공유
Wow apparently so , I guess that's what happens when you don't bother to read all posts. My apologies.
의 공유
Yup, happens all the time ;-)
의 공유
how do u use the switch
의 공유
댓글 달기
답변을 추가하세요
William Greene 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 37
전체 시간: 11,575
