주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 Short - KEEP Restarting
Hi Everyone, Hi @refectio Sir.
I have an iphone 6 ( its our personal phone , not water damage)
The phone simply drop down, and keep restarting.
Sometime, we can use it for some hours and then begin restarting.
I connect it to DCPS , phone absorb 0,08 amp (after ONLY battery connected)
The strange thing is, if i connect battery (i already try with new battery) the phone turn on automatically, without press power button.
If the battery is dead, the cable and battery logo appear continuously on the screen.
It seems, like someone press power button continuously.
i check all cap diode and filter connect with power button FPC but everythng is well.
Tristar , Tigris voltage is ok, phone charge normally.
I really dont understand how can i remove this short.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Remove the board and connect only a known good Lightning Port and Battery. Then connect it o a charge or an iTunes enabled computer and see if it boots properly and stays booted over time. If it does, then connect a screen and do the same test.
The issue may be with the power button flex (or power button) which was damaged by the drop.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank u @minho SIR.. i already tried only board connect with dcps, but when i connect battery cable, phone turn on immediatly..
Evertything is perfect, the only problem its restart often automaticaly and absorb 0,08 amp (with battery cable connect, withput power on)
Thanks
댓글 달기
귀하의 답변을 추가하세요
AGS 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 52
