주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
260 질문 전체 보기
A1707 - Blacklight Flicker
Hi,
Just picked up a 2nd User 15” MacBook Pro with Touch Bar (A1707).
I’ve just noticed it sometime seem to go though a state of the blacklight flickering for a minute of so. More when I’m moving the Device (carrying) however if I change the brightness it will flicker for a second. Its not all the time. Just the odd now and then.
Anything I should be worried about?
Update (02/01/2019)
Additionally. I’ve turned off Auto Adjust Brightness and that seem to have stopped the issue. If that help? Is it a know problem?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Does tapping on the lid make it happen? Is the angle of the lid effect it as well?
댓글 달기
답변 1개
가장 유용한 답변
Does the whole backlight flicker or do certain areas such as the bottom flicker?
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
The whole screen.
I read an article a few days ago about a possible hardware issue with the newer macbook pro's that causes this, because of the way the cable for the video and backlight is bent. It's been dubbed "flex gate".
https://venturebeat.com/2019/01/22/apple...
Hi. Sorry for the late reply. The whole screen flickers and after a bit of testing it's is something to do with the "Automatic Backlight Adjustment" turn that off and the problem seems to go away. With it on, if you move it just seems to be quickly/rapidly adjust the backlight.
Ah, ok. There is a cable that controls that I believe and it's an easy repair. Let me see if I can find more info about that.
댓글 달기
귀하의 답변을 추가하세요
Andy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 565
