주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
Optical drive no power
Hello, I fixed the optical drive roller which was misplaced to fix the CD intake problem, This problem was fixed but I was still getting error with disk reading so I decided to replace the laser kit. I successfully replaced it. I restarted my PS4 but no activity in optical drive. It is not doing anything. Seems there is no power. It seems something got wrong during re-assembly. Not sure how to fix now. Any suggestion and how to check if optical drive is getting power. did any cable got bad?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
maybe you nicked a cable going to the drive , or its a software issue
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Most laser assemblies ship with a shorting solder connection on the ribbon cable to prevent static damage. Look carefully at the cable on the optics assembly itself for a small “bubble” of solder. Remove this and the laser should work. Since the assembly won’t attempt to spin the disk unless one is detected (laser lights and detects the reflection if a disk is there), it may appear that the assembly has no power. Check for the short and update this with what you find. If you can, post a few pix of the assembly from different angles too.
Dan
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
lucknow_99 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 68
