주요 콘텐츠로 건너뛰기
Kinect is a gaming peripheral for the Microsoft Xbox 360. It allows for audio and video input to let the player be the controller.
What are the physical dimensions of the Kinect device?
What is the height, width and depth of the Xbox Kinect camera, and does the cable require you additional clearance from the wall beyond the overall depth of the device?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Of course you are asking this because you want to either repair it and/or incorporate your Kinect into a different entertainment center, thus making it repair related? ;-)
The height, width, and depth of the Kinect itself should be listed in its user manual. Look through it to see if it's listed.
If not, a search on Google should bring it up.
댓글 달기
답변 2개
선택된 해법
Michael Emery, just measured mine :
Length 11"
height 3"
depth 3" at the widest part (the base)
the cable exits from the rear of the base, so you would have to give it some extra depth to accommodate it. Good Luck and I hope this helps.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
420 cm hieght
420 cm lenght
420 cm depth
just measured her up braz
이 답변이 도움이 되었나요?
점수 -1
댓글 2개:
Thank you this helped a lot
@blazeit your measurement make the Kinect a cube. You want to double check this? You also want to refrain from having your super ego vote up your wrong answers.
댓글 달기
답변을 추가하세요
Michael Emery 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 23
전체 시간: 19,453
