주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Swap Body To Change Keyboard Layout
Hello, I have a 2010 15” MacBook Pro with spanish keyboard layout and I wanted to swap the body to one that have an US keyboard, is that possible?
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Yes, sure, no differences whatsoever internally. You can use the following guide as a reference, although it’s for the following year model, screws and connectors are about the same:
MacBook Pro 15" Unibody Early 2011 Upper Case Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Thank you so much
@brunobvm - The US keyboard is a very different from the ISO keyboards. So you can't just replace the keyboard subassembly you need to replace the full uppercase.
Unless your keyboard is messed up I would just replace the keycaps and go into the keyboard preferences to alter the driver to the U. S. ISO source.
Here's the source of the keycaps TheBookYard UK
That’s a wonderful solution, how couldn’t I think about it?
I even have an old MacBook Pro that I can remove the keys.
Thanks a lot.
댓글 달기
귀하의 답변을 추가하세요
Bruno Melo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 75
