주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
MacBook Pro retina early 2015 no power, logic board fried
So my MacBook Pro early 2015 13” retina gave out on the weekend, apple says the logicboard is fried , because of how expensive it is I rather sell for parts. With that said I need my data off of the hard drive, was told it’s doable even with out the laptop turning on? And that I needed a hard disk drive adapter to transfer out the data? Any suggestions on the kind I need
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Before you assume Apple diagnosed things correctly can you tell us what happened and what is the system doing now or not doing. As an example is the MagSafe charger LED Amber or Green? Is the fan coming on when you press the power button? Do you see any glow in the lid logo?
It was working fine last Saturday, when I tried to wake it up Monday I assumed it was dead. I charged her up a bit and it just never turned on, no noises I don’t hear the fan or any chime, or see any glow on the logo. The chargers led does light up, its on green because I’m guessing it’s fully charged now. any help would be appreciated! Thanks
댓글 달기
답변 3개
선택된 답변
Apple doesn’t repair customer’s logic boards, they want them to buy new more expensive and less serviceable machines, the faster they can push this evil logic the more profits they make, this is a fact. However another fact is that there are a number of reputable labs who don’t share Apple views and _do make_component level repairs..find one and you might be able to get back your Mac working at a fraction of the cost of a new one.
If you still want to dispose of yours look for a 12+16 pin Ssd adapter for Mac, on big marketplaces like Amazon or eBay you won’t have any problem to find a cheap one and recover your data.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Lets try disconnecting the battery MacBook Pro 13" Retina Display Early 2015 배터리 교체, stopping at Step 6.
Then press and hold the power button for a good 15 secs so the system is fully discharged. With the battery still disconnected plug in the MagSafe charger it should be Amber.
Now try powering the system by pressing the power button. What happened?
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
this helped get a "dead" unit working for me. it would charge up but not power on. i disconnected the battery and the unit powered up. i confirmed everything was working and then reconnected the battery and its still working. perfect!
댓글 달기
Nobody seems to want to answer your question, so I’ll kick in.
To recover your data get a
OWC Envoy Pro
Portable, Bus-Powered USB 3.0 EnclosureFor Apple Flash SSDs (June 2013-Current Mac Models)
https://eshop.macsales.com/item/OWC/MAU3...
Remove your SSD card, put it in this enclosure and plug into another Mac.
MacBook Pro 13" Retina Display Early 2015 SSD Replacement
Apple offers “Flat Rate Repairs” on macs that have not had liquid or impact damage at a reasonable cost of $357.00, tax and shipping included. They will fix any and all problems for that price. But you will probably lose your data so back the drive up first. Total time is usually four days including the day you call. Simple call 1-800- MYAPPLE.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
@mayer - I was hoping Apple messed up and try to properly diagnose & hopefully get the system fixed ;-}
Well, I didn't directly linked a specific product but I did answer ;)
댓글 달기
귀하의 답변을 추가하세요
Larry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 950
