I keep getting oil in my spark plugs
I keep getting oil in my spark plugs and I’ve already replaced the valve cover and gasket. How can I fix this?
좋은 질문입니까?
좋은 질문입니까?
Hi @noremac168 ,
Is there blue smoke coming from the exhaust?
This link gives some of the reasons for oil in the spark plug well. (scroll down to the Common reasons for this to happen: paragraph)
이 답변이 도움이 되었나요?
No it’s white but it smells like burning oil
Hi @noremac168 ,
White is also not good. It usually indicates coolant getting into the cylinders/exhaust manifold.
Are you also losing coolant?
Does the oil on the dipstick have a milky look or even bubbles?
I’m not losing coolant just oil
Hi @noremac168 ,
Are all the plugs covered in oil or only one or a couple?
If not all then it may pay to get a compression test done on the cylinders to check if the leak may be through the rings or the valve guides
After I replaced the valve cover it’s been just one
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 2,969
