주요 콘텐츠로 건너뛰기
The Dell OptiPlex 755 USFF smallest form factor of OptiPlex 760 series
connects to tv but not monitor
i own a optiplex 760 usff , it succesfully connects to tv’s using dvi to hdmi, but not dvi to dvi for my monitor
pls help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 7개
Hi @fegelein3290 ,
What is the make and model number of the monitor?
What resolutions does it support?
Have you tried a different DVI cable?
Do you know for sure the monitor works? Have you tried switching inputs on the monitor?
yes ive tried a lot
ive tried on 3 different monitors actually
Are you using the same DVI cable among the 3 monitors as well as the TV? What pin style is the DVI cable you are using vs the pin style on your Optiplex vs the DVI pin style of the TV?
댓글 2개 더보기
댓글 달기
답변 2개
선택된 해법
Based on your responses in this thread, I suspect a DVI-I (male) to DVI-D(Female) may do the trick, the adapter itself is ~$3 online
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
indeed i believe so too
댓글 달기
If your monitors support HDMI, maybe just keep the connection of DVI to HDMI.
Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
well thats the thing i have no hdmi monitors only 15pin vga and dvi
Does the machine have VGA? Because if so, you can use that connection.
my desktop ony has 9 pin vga and dvi
ok, so i looked the optiplex has a dvi-i port but the dvi cable and the dvi to hdmi boh are dvi-d
댓글 달기
답변을 추가하세요
Brayden S 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 268
