주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
There’s a thing on the bottom right of my screen
There’s this graph looking thing that is on the bottom right of my screen and it’s really annoying
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Hi,
Post a close up image of the affected area of the screen.
Here's how to do this. 기존 질문에 이미지 추가하기
Hi sorry I've been late my PC was broken for I don't know how long but please respond
Hi @benjamen50 ,
Would be interested in your opinion/answer on this one.
Cheers
댓글 달기
답변 2개
가장 유용한 답변
That is liquid gone into the backlight diffuser film that is a layer that sits behind the display panel. You’ll need to get the screen replaced to fix this.
I would be worried that liquid may have gotten into the phone. You may want to open it up or take it to a reputable repair shop for internal inspection for liquid damage.
iPhone 6 Screen Replacement
iPhone 6 Screen
iPhone 6 Screen 이미지
상품
iPhone 6 Screen
$44.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
To be honest I thought it was pressure marks because the spot gets reduced everyday , and there's no way superglue can get into the screen. It also happened when I removed a screen protector when it was stuck on tight.
Pressure marks would be yellow bright marks on the screen or white circular pressure marks.
Well since you've mentioned super glue then that would most likely be in the backlight layer of the screen. Be careful when removing screen protectors, some are glued in very strong so take your time taking one off.
댓글 달기
most likely liquid damage
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
George ie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 66
