Help! Split liquid on trackpad MacBook 12” what to replace?
I had Spilt coffee on my MacBook Pro 12” notebook my trackpad is not working would what would I need to replace to repair it!? Thank you for you’re time much appreciated!
Update (02/16/2019)
My MacBook 12” is completely functional except the trackpad. Would I only have to replace the track pad and the trackpad flex ribbon cable?
좋은 질문 입니까?
댓글 3개
You can also buy the ribbon cable here: MacBook 12" Retina (Early 2016-2017) IPD Flex Cable
I would inspect the connectors for liquid damage first however. I also don't think you would need to replace the cable necessarily. If you can't clean out the damage, just a replacement trackpad with your original cable will probably work fine. I would try that before buying a replacement cable as well. Especially if your keyboard still works.
Jonah Aragon 의
Okay thank you! Can I get a link for the right replacement tools I would need to take apart the MacBook?
Shay Whitford 의
https://www.ifixit.com/Store/Guide/97072
Jonah Aragon 의
